12-30-2013 11:20 AM - edited 07-04-2021 11:52 PM
I'm running Windows 8.1 and not having any luck with OpenSSL. Is there any other means to generate a CSR for a WLC 5508 web auth cert?
Thanks.
Solved! Go to Solution.
12-30-2013 11:41 AM
I have always used OpenSSL light v9.8 and never had issues. You can always use another method to generate a CSR, but you have to convert the cert they provide you to a pem. There are online conversions but to me that is more of a hassle.
01-20-2014 07:34 PM
I think you're referring to OpenSSL version 0.9.8 (not v9.8).
The bug you're referring to is:
https://tools.cisco.com/bugsearch/bug/CSCti65315
Fixed in WLC 7.5 and 7.6 (and 8).
01-20-2014 10:18 PM
Usually you can get Linux OS installed (virtually) and get openSSL to work on it.
If your issue is with the OS, you can virtually install any older windows version (windows XP, windows 7) that works fine with the 0.9.8 OpenSSL. Generate the CSR then remove the VM.
Rating useful replies is more useful than saying "Thank you"
01-21-2014 04:14 AM
I typically just have OpenSSL installed on a Windows VM in my Mac. To me, there is no need for me to install v1.0 since 0.9.8 works fine for all versions of WLC code. The biggest issue was people were downloading the latest version of OpenSSL which didn't work with the older versions of code until Cisco supported that on the later versions. We still use the 0.9.8 versions because we still see customers who standardize on the 7.0 or other code versions that only work with 0.9.8. There just isn't a need to upgrade for a tool to create a CSR. We also use the windows version because we automate this process which makes it easier for us.
12-30-2013 11:41 AM
12-30-2013 11:44 AM
Thanks Scott. I'll try that version.
12-30-2013 11:46 AM
There use to be an issue with OpenSSL v1.0 but some say it works, but I haven't tried it since v9.8 works like a charm:)
01-20-2014 07:34 PM
01-20-2014 07:58 PM
Yeah that's what I meant. I still use that version as it still works the best. No need to have two versions because you might still need to creat a CSR for older version WLC's.
01-20-2014 10:18 PM
01-21-2014 04:14 AM
01-21-2014 07:47 AM
Last week I installed Ubuntu on a spare SSD I had sitting around and just boot that when I need OpenSSL.
Thanks.
