Hi Team,
We enabled a setting on ISE to begin allowing PEAP session resume and fast reconnect (clients were configured previously to support this)
After we did this we are having an odd issue with clients who are coming traveling between a local connected SSID and the same SSID in a flex connect office.
Use case:
Client(laptop / Win 10 / SSID ABC / Local mode AP) works fine at location 1, user travels to any remote office and connects to the same SSID ABC (in remote offices these are flex connect) gets an new dhcp ip address and works fine.
Client than travels back to location 1 and connects back to the same SSID and is authenticated just fine, however is provided the DHCP address that it had in the remote office (flex connect), which does not work for this local mode connection in location 1. Forcing the client to ipconfig /release / renew fixes this.
Any thoughts? will score for good info!
