01-04-2018 01:16 AM - edited 07-05-2021 08:02 AM
Hi all
I would like to install the latest hotfix offered in my PI 3.2.2 installation (PI_3_2_2_update_01-1.0.8.ubf) but Prime throws the following error:
sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Do you also get this error?
This happens when I click the Download button in the PI Software Updates interface.
Solved! Go to Solution.
03-01-2018 08:12 AM
Just found this bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvh32926
There is also a workaround:
Open a TAC service request to have the certificate file QuoVadis_Root_CA2.pem posted through the Special File Posting process. Once you have it, transfer the file to a location on your Prime Infrastructure server that has a repository defined, such as /localdisk/defaultRepo, then manually upload the file from local storage using the following command: ncs key importcacert QuoVadis_Root_CA2.pem repository For example: ncs key importcacert admin QuoVadis_Root_CA2.pem repo defaultRepo After uploading the certificate, restart Prime Infrastructure with "ncs stop" and "ncs start", or navigate to Administration > System Settings > Server, and click the "Restart Prime Infrastructure..." button. You can close your TAC service request after successfully completing this workaround using the tools at https://mycase.cloudapps.cisco.com/case
Please note, you could probably also download the original root cert from here: https://www.quovadisglobal.ch/Repository/DownloadRootsAndCRL.aspx
01-04-2018 02:09 AM
- This is a JAVA error, clearly someone messed up, (contact TAC); you could as a workaround download the ubf from cisco.com and install it manually.
M.
01-04-2018 02:17 AM
01-04-2018 02:21 AM
- No, I get the same error , indeed, ; as stated you could try the manual download and install
M.
01-04-2018 07:04 AM
Was their a fix for the issue?
01-04-2018 07:06 AM
01-04-2018 07:07 AM
01-04-2018 07:15 AM
01-04-2018 03:01 PM
I was able to upload a 4g file to this server yesterday with tftp but today when I try it it gives me this error.
The file today is .03mb.
01-04-2018 03:05 PM
01-05-2018 12:03 AM
01-04-2018 07:13 AM
- Actually , if you look at the release notes, of the ubf, in the install procedure , ONLY the manual download is mentioned. It's not sure wether this must be seen as a requirement,one could argue; it should then not be advertised in the prime->administration -> download center , but then one could be abstinated of it's existence too...
M.
01-04-2018 07:35 AM
01-04-2018 07:42 AM
- Does this then give the same errors ?
M.
01-04-2018 07:47 AM
