07-02-2020 08:04 AM - edited 07-05-2021 12:14 PM
Hello together,
i want to monitor the AP-Controller "AIR-CT2504-K9" and his managed AccessPoints "AIR-AP2802I-E-K9".
Main goal is that i can Ping all APs but actually it doesn't work.
I find a section where to enable SSH, HTTP(S) and SMTP but nothing for Ping.
It is not a problem of the firewall (all traffic allowed both directions, routes configured), and the APs have there correct IP, Subnet and Gateway.
So i guess that they may not answer the Ping-Request or may not route back to the Ping-Source or something like that.
Do you know this problem?
Ping Source is e.g. 172.16.10.1 / 255.255.255.0 / Gateway 172.16.10.254
Target AP is e.g. 172.16.25.1 / 255.255.255.0 / Gateway 172.16.25.254
Best Regards,
Dancis
Solved! Go to Solution.
07-09-2020 10:38 PM
Hey people,
your're right.
Problem was not the firewall and also not the AP.
Problem was a misconfigured switch where the appropriate VLAN was not added to Trunk.
Ping is possible without any configurations.
Thank you for helping.
Best Regards
Dancis
07-02-2020 06:34 PM - edited 07-02-2020 06:36 PM
07-09-2020 10:38 PM
Hey people,
your're right.
Best Regards
Dancis
07-02-2020 10:54 PM
If PING is not wiorking between two diff subnets then it must be an issue of routing or firewall blocking!
Dont forget to rate helpful posts
