Where are the AP groups in PI 1.3 ?
The documentation in PI 1.3 states
Step 1 Choose Configure > Controller Template Launch Pad.
Step 2 Click AP Groups or choose WLAN > AP Groups from the left sidebar menu.
AP groups in the controller itself shows the applied template names, but there are no templates ???????
Solved! Go to Solution.
Have you looked using classic theme and not the default lifecycle theme. Click on the root on the top right and choose classic theme. Also you might need to discover templates from the controller as they don't sync the information.
In lifecycle theme, all the templates found in the WLC should be populated. So it depends on what theme you choose.
http://www.cisco.com/en/US/docs/wireless/prime_infrastructure/1.3/configuration/guide/temp.html#wp1073214
thank you, it works
Good to know:)
