Prime Infrastructure 2.2 Upgrade to 3.0
bm_5789
I am trying to do an inline upgrade from PI2.2 to PI3.0.  I copy the upgrade file to defaultRepo and start the ujpgrade process.   and verify the MD5 and SHA512 Checksums.  When I start the install, I get the following:
Initiating Application Upgrade...
Stage 1 of 7: Transferring file ...
-- complete.
Stage 2 of 7: Unpacking file ...
% Unable to unbundle the package. Package may be corrupt or there is not enough disk space
I verify the MD5 and SHA512 Checksums and they are correct.
What disk space might be the issue.  Can anyone advise what I should look at next.  TIA
7 Replies 7
Is it appliance or VM? If its appliance is it Gen 1 or Gen 2 ?
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
It a physical appliance, Gen 1. The document I have indicates I can do an inline upgrade from 2.2 to 3.0 on a Gen1 appliance.
Thanks for your help.
Version 3.0 is not supported on Gen 1 appliance . Ref Prime 3.0
I understand Cisco will not support PI 3.0 on Gen 1 appliance.  However it can be done.  So I was looking for info from someone who has performed the upgrade.  Thanks again for your help.
 - #wasteoftime
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
You probably first need to replace the hard disks with larger models and then do a complete fresh installation, which will never be supported.
Check this once please Disk out of Space issue
