08-05-2020 07:23 AM - edited 07-05-2021 12:21 PM
I have to upgrade Prime 3.3 to 3.8.
If I run the CLI command "show startup-config" it produces output.
If I run the CLI command "show running-config" it produces no output (other than 'Generating configuration...') and just freezes till I do a ctrl c.
Any reason why "show running-config" produces no configuration output?
08-05-2020 07:27 AM
08-05-2020 10:00 AM
- As far as I understand it, this direct upgrade-path is not supported. You have to go to 3.7 first , then install a virgin 3.8 and restore from a 3.7-backup. Anyway re-visit the release notes for 3.8 and scrutinize the install and upgrade procedures.
M.
08-06-2020 12:28 AM
hi
Thanks for your reply.
I already know the upgrade path from Prime 3.3 - 3.8.
I would like to know why running the commands:
or more concerning that
"write memory" provides no conformation that the configuration has been saved?
08-06-2020 12:50 AM
- Log on to your current Prime deployment (SSH) and check it's health with the ncs status command
M.
08-10-2020 01:28 AM
All looks fine. Is there something I should be looking for?
admin# ncs status
Health Monitor Server is running. ( [Role] Primary [State] Primary Active )
Database server is running
FTP Service is running
TFTP Service is running
Matlab Server is running
Matlab Server Instance 1 is running
Matlab Server Instance 2 is running
Matlab Server Instance 3 is running
NMS Server is running.
SAM Daemon is running ...
DA Daemon is running ...
WSA service is running ...
wsa apache httpd is running...
Compliance engine is running
/admin#
08-10-2020 02:56 AM
- Have a cold boot/restart , carefully scrutinize the startup process, make sure no errors are seen when services are started. Afterwards, if the problem persists have a look at system performance (memory, disk, cpu) both from a local view , and if this is a VM also look at hypervisor performance values for the Prime VM, check if no bottlenecks are observed.
M.
08-18-2020 08:08 AM
08-18-2020 09:13 AM
They don't work on current Prime 3.3.
I would not venture to perform an upgrade on Prime if these rather fundamental commands were not working.
Also perform an application stop/start and the problem still persists.
Next will be an appliance reboot.
08-19-2020 12:03 AM
