03-02-2015 10:25 AM - edited 07-05-2021 02:38 AM
If I apply the Demo license to a licensed Prime Infrastructure server will it enable all the features so I can test the Netflow features for the demo period? I have never used the Netflow features and would like to test drive for a little and decide if we want to move of our current platform.
Thank you all.
Solved! Go to Solution.
03-03-2015 01:51 AM
You purchase licenses to access the Prime Infrastructure features required to manage your network. Each license also controls the number of devices you can manage using those features.
You need a base license and the corresponding feature licenses (such as Assurance or Data Center licenses) to get full access to the respective Prime Infrastructure features to manage a set number of devices.
If you have installed Prime Infrastructure for the first time you may access the lifecycle and assurance features using the built-in evaluation license that is available by default. The default evaluation license is valid for 60 days for 100 devices. You can send a request to ask-prime-infrastructure@cisco.com if:
When troubleshooting licenses, it is important to remember that Prime Infrastructure has five types of licenses:
All five types of licenses are supplied as either evaluation or permanent licenses:
03-03-2015 01:51 AM
03-03-2015 08:42 AM
So I guess I can apply the demo license and it will enable the areas that I have not had demo license before. When permanant license gets purchased it overrides the demo for that particular area.
Another item I have been trying to determine is the concept of the Data Center license. We have Nexus 7k and below do we need Data Center to manage these now or will it be covered under my current Lifecycle license. I think the implication is the Data Center is for the computing side (UCS).
Thank you.
JC
