Highlighted
Beginner
Prime Infrastructure WLC9800 AP Tags
Hi All,
We got access points with static Tags assigned. In Prime Infrastructure 3.8 I can see the Tags but I cannot find a way to edit them through Prime? The Tags are displayed in Device Details. Does anybody know if this is possible?
Urs
3 REPLIES 3
Highlighted
Hall of Fame Master
If a template is not available, then you can create a cli template that you can use to push the changes out.
-Scott
Highlighted
Thanks a lot. So we will still edit the tags using the WLC CLI what's probably the easier way.
Highlighted
Either one is easy, just depends on the person whom is running the job. If you know and understand the cli, that is easy, templates takes a bit to get use to, but in the end it’s all about pushing the settings properly.
-Scott
Content for Community-Ad
