Prime Maps - Adjust building height in Prime 3.4
mgriffit
Hello
Can anybody tell me if it is possible to modify the height of a building map in Prime 3.4?
We have a situation where we need to adjust the height of an imported building from of 3m to 5.5m.
I don't appear to be able to re-adjust this height without recreating the building from scratch. Is this the case?
best regards
Martyn Griffiths
University of South Wales, UK
d.friday
Level 4
Level 4
you can change the Floor Height, this will have to be done for each floor.
This can be done by opening up the floor you want to change, select edit and select floor height.
Sandeep Choudhary
Normally you can edit the Dimensions and Positions of buiding!  I dont think there is an option of height change for building in CPI.
Dont Forget to rate helpful posts
d.friday
Level 4
Level 4
Many thanks d.friday.
I had seen that under the "floor" options before, but I'm sure when I attempted to change it previously it wouldn't take effect.
I've now tested it again and it appears to have taken the new height. Brilliant :o)
best regards
Martyn
