Cisco Community Designated VIP Class of 2020
23315
Highlighted
Re: Re:Prime NCS not starting
what helped there?
Contributor
I will add this. My experience is that once this happens it will most likely happen again.
If you are not running the latest 1.3 build I would suggest you upgrade.
Sent from Cisco Technical Support Android App
Beginner
Re: Prime NCS not starting
Thanks a lot
Will upgrade soon to 1.3
Content for Community-Ad
August's Community Spotlight Awards
