Query on Raw-Netflow in Cisco Prime Infrastructure 3.1.7
BhaskarDS
Hi All,
I have a query regarding Raw-Netflow in the Cisco Prime infrastructure.
In one of the document I see the custom netflow has been deprecated for 3.2 version. But when I checked Custom Netflow Template in the Prime 3.1.7, it is showing deprecated.
Has the Raw-Netflow been deprecated for the Cisco Prime Infrastructure 3.1.7 ?
Is the Custom Netflow and Raw-Netflow same thing ?
I can see deprecation reason given below in 3.4 user guide.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-4/user/guide/bk_CiscoPrimeInfrastructure_3_4_0_UserGuide/bk_CiscoPrimeInfrastructure_3_4_0_UserGuide_chapter_0100011.html
"Custom Reports option in the NetFlow Templates page is deprecated from Cisco Prime Infrastructure Release 3.2, due to high disk space usage. You can generate the report from the Reports > Reports Launchpad > Raw NetFlow page"
Rasika
*** Pls rate all helpful responses ***
Hi Rasika,
Thank you for your reply.
Actually I saw that 3.4 user guide earlier. But there it is saying 3.2 version. However, here under template it is showing as deprecated in the 3.1.7 version also. I have attached the screenshot for your reference.
