Highlighted
Beginner
Radio won't enable
Greetings,
I've setup the following AP1041N configuration, but for the life of me - the radio will not enable.
Can someone do a check?  Thanks.
sho conf
Using 3234 out of 32768 bytes
version 12.4
no service pad
service password-encryption
hostname MAP_1
logging rate-limit console 9
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ip domain name IHI.local
ip name-server 172.16.0.33
ip name-server 172.16.0.9
dot11 syslog
dot11 ssid Admin
   vlan 30
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii 7 020A075E1C0F1D24404B1A0A
crypto pki trustpoint TP-self-signed-319899067
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-319899067
revocation-check none
rsakeypair TP-self-signed-319899067
crypto pki certificate chain TP-self-signed-319899067
certificate self-signed 01
  30820249 308201B2 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33313938 39393036 37301E17 0D303230 33303132 33343035
  335A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3331 39383939
  30363730 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  DDADD8FC CD117FAA 38E21BD1 537E3A73 5E7FAC56 222F8FEE E4F4C16F 0BF64DB5
  A5AABD5B 10AE9241 DFE71027 00EF9318 7A22FC7E B3C1EB56 010E6E04 BEF0A9B5
  2B0DB4AB 676A6828 AF081340 37566439 1D50E6FA CDF92E2B B49730A5 96BCBFAB
  EEF77740 9379E69F 318894E1 EF38D410 7E963233 6B00F7AD 9807ACBB 79D9EA55
  02030100 01A37330 71300F06 03551D13 0101FF04 05300301 01FF301E 0603551D
  11041730 1582134D 69616D69 41505F31 2E494849 2E6C6F63 616C301F 0603551D
  23041830 1680143C B8ACD446 2FCB1C2D 1208384C 7250CD21 A775B130 1D060355
  1D0E0416 04143CB8 ACD4462F CB1C2D12 08384C72 50CD21A7 75B1300D 06092A86
  4886F70D 01010405 00038181 005109CF 3DEF417E F19220F0 C1F930F7 A8D75DE5
  283166D0 4FB10AD2 213EF9C9 0684B7A2 85F6FAFC AF3E96E9 5F54694C F532FB6C
  B7B1BB65 A501EA2B A98000A3 645C4884 49AEA766 CA111E94 95383EDC F0332208
  F4F55202 59EEBC73 3E4BD6E3 CB4120AB 106FE542 97E35FF9 0B6AD65B 02C178E8
  FF3A6295 31139638 86C5AF0F 97
  quit
username admin privilege 15 secret 5 $1$nC8s$fOV/oYcfHZzFrdIt/OkaW.
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
encryption vlan 30 mode ciphers aes-ccm
ssid Admin
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.9.252 255.255.255.0
no ip route-cache
ip default-gateway 192.168.9.254
no ip http server
ip http authentication aaa
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community default RO
bridge 1 route ip
line con 0
line vty 0 4
end
1 ACCEPTED SOLUTION
Highlighted
you can actually do a no vlan 1 under the ssid, as it's not needed.
then under the radio remember to reconfigure the encryption, and you may need to reset the SSID
Int Dot 0
encryption mode ciphers aes-ccm
ssid Admin
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
10 REPLIES 10
Highlighted
Hall of Fame Master
Your radio is disabled:
Config t
Interface dot11radio0
No shut
Exit wr mem
-Scott
Highlighted
Sorry if I didn't make that clear -
No shut doesn't work - it remains in a shut state.
Highlighted
Were you able to bring the radio up with the defualt configuration?
-Scott
Highlighted
you're calling a VLAN in the SSID config, but you don't have the sub interfaces created.  What VLAN is the AP in?
Steve
Highlighted
That's why I need a better set of eyes
The AP is in VLAN 1
What now?
Highlighted
OK - I just changed the VLAN from 30 to VLAN1 under 'dot11 ssid Admin' - and the came up after issuing 'no shut'
but I'm not seeing the SSID 'Admin' broadcast in my wireless on my latop.
Highlighted
under the SSID, you need to add guest-mode, this makes the AP send the SSID in teh beacon messages.
Steve
Highlighted
I did that- still nothing.
Here's how it's currently setup:
dot11 ssid Admin
  vlan 1
  authentication open
  authenriation key-management wpa version 2
  guest-mode
  wpa-psk ascii 7 0200A075 .......
Highlighted
Int Dot 0
ssid Admin
Steve
Highlighted
Thanks Steve - that did the trick!!!
Great community of experts to count on in a pinch.
