ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Radius Authentication
Hello Everyone,
I am having Cisco 2504 WLC. I want to use radius authentication on one of my SSID's. Whenever I try to connect to the SSID having radius authentication enabled I am unable to connect to that SSID.
Anyone aware what can be the issue? My radius server is running on Windows Server.
2 REPLIES 2
Highlighted
VIP Mentor
What does radius logs says
What does radius logs says about this ?
Also if you get "debug client <client_mac_address>" output that will give you a hint what's missing.
Also attach "show wlan <wlan_id>" output to see the config of WLAN as well.
Rasika
*** Pls rate all useful responses ****
Highlighted
Made some changes on the
Made some changes on the radius server and then it started to work
Content for Community-Ad
