Radius NAC VLAN select support
patrick.kofler
Hi all,
I have digged through the WLC documentation for 7.3 and in the chapter about Radius NAC I read that the VLAN select feature is not supported.
Does anyone know if this will change?
VLAN select is actually a useful feature and I wouldn't understand if NAC support over the ISE won't be possible.
Hope someone can shed some light on this.
Patrick
Tarik Admani
I think with radius the vlan select and dynamic vlan assignment are two different topics. You can have ISE set users on different vlans within the same WLAN as long as the interface is present on the controller. I have tested this and works just fine.
The vlan select maybe a topic that the wireless folks can shed some light on.
Tarik Admani
*Please rate helpful posts*
