ā07-25-2019 12:11 PM - edited ā07-05-2021 10:45 AM
I'm using an AP 2802e with mobility express 8.8.111, I have a ssid with external web auth using a captive portal (externally hosted).
In this portal users introduce their credentials and the radius server response if they are allowed or not.
This is working perfectly, but now I need to limit the session time and upload/download speeds per user.
When a user is successfully authenticated, the radius reply attributes are as follows
Acct-Interim-Interval = 300
Session-Timeout = 2700
Download = 4096
Upload = 4096
But in the ground this parameters are not being apply by the AP to the clients, seems there's specific vendor reply attributes to define this parameters, but I haven't found any documentation regarding which reply attributes i should have for the mobility express AP, the only ones I've found are for other series of cisco's wlc.
Which attributes should i reply at the moment of authentication or the mobility express hasn't the capability to define timeout and speed based on radius parameters?
I'd really grateful if can point me in the right direction.
thanks
ā07-26-2019 08:15 AM
I moved your discussion to Wireless Security and Network Management as your inquiry is specific to Mobility Express.
ā07-31-2019 07:02 AM
