Renewal Certificate ISE
dungtran.90
Dear All
I have a case below:
I have an ISE node. EAP certificate is expired so I renewal it and received the certificate from Zone which is using normal for other sites ( Europe, India, America..) But in Vietnam, we met the issue as the picture below. We change the EAP certificate from Comodo to Sectigo. Import successfully to ISE, a client can connect now, but it does not automatically connect anymore, every time we move to another AP we need to click connect twice.
Could you please help or support?
DungTran
5 Replies 5
patoberli
Do you have more than one Radius server configured? If yes, do both use the same root certificate / issuer of the certificate?
If not, then this is the normal behavior.
Make sure that the certificate shown to the client is actually the correct one and not a Man in the Middle attack with a rogue access point.
"show certificate details" may guide you to the root cause
possibilities:
- the host-name does not match the name in the certificate
  this would be immediately shown
- when using multiple ISE servers , you may need to configure SAN names in the certificate
  certificate details -> alternate names
- you may have imported a certificate with incorrect certification-chaining
   certificate details -> certification path
ammahend
Some additional basic checks ...
verify Sectigo root cert chain in present on client.
On ISE end I am sure you check Sectigo root cert to be used for client authentication.
-hope this helps-
Dear Ammahend
Root cert already verified by Zone.
So in the ISE end, i need to enable: Trust for client authentication and Syslog ?
DungTran
yes If you are using this certificate for client EAP auth.
-hope this helps-
