04-15-2012 04:19 AM - edited 07-03-2021 10:00 PM
hi,
i have a requirement to allow only certain device types (Apple Ipad only) on WLAN. Dont want to use individual MAC filters due to administrative overheads. Any suggestions?
04-15-2012 06:16 AM
The only way you can just allow one type of device is the use of a profiler. Cisco ISE has a profiler, but you will need to get the advanced license also. I don't know how you would be able to do it any other way unless you manually configure each iPad to allow that device on your network.
04-18-2012 04:59 AM
Thanks for reply... can we somehow manage to identify Ipads with its pre-installed certificates?
Or can list of OUI help us in this regard?
Becuase ISE is not available here at the moment.
04-18-2012 10:03 AM
the OUI list won't help. it's not specific to the device, just the manufacturor. So if you were to block by OUI, you would stop all Apple devices from being able to get on the network.
Steve
