Highlighted
Beginner
Beginner
Roaming issues with WLC5508 - FlexConnect with WPA2/PSK
On a wifi installation, some devices seem to lose connectivity sometimes. The interuption is very quick but significant for their applications.
The controller is a Cisco WLC5508 with the release 7.4.100.60 and the access points are Cisco 1242 (with two external antennas) and 1602.
APs are in Flexconnect mode, and SSID security is in WPA2/PSK.
I don't see any problem with my HP laptop, but with Samsung Galaxy Tab or LXE devices the problem is present.
In the message logs, i found this frequently :
*apfReceiveTask: Jul 01 11:50:17.521: #LWAPP-3-INVALID_AID2: spam_api.c:1357 Association identifier 9 for client 00:26:37:d5:fe:ba is already in use by 00:26:37:ed:0f:1a
And this :
*Dot1x_NW_MsgTask_4: Jul 01 10:01:02.144: #DOT1X-3-INVALID_WPA_KEY_MSG_STATE: 1x_eapkey.c:861 Received invalid EAPOL-key M2 msg in START  state - invalid secure bit; KeyLen 24, Key type 1, client 00:26:c6:07:98:44
But i'm not sure that these logs occur a connectivity lost.
Is anyone had roaming issues with this configuration?
Thanks by advance for any response.
5 REPLIES 5
Highlighted
Hall of Fame Master
Can you post the show run-config
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Highlighted
Beginner
Beginner
Re: Roaming issues with WLC5508 - FlexConnect with WPA2/PSK
Hello Scott,
Please find attached the "show running-config" of the controller.
Highlighted
Hall of Fame Master
Try not to have both WPA and WPA2 setup.  Either use WPA/TKIP or WPA2/AES
This is for your SSID: INTERNAL
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
Scott
-Scott
Highlighted
Hall of Fame Master
Also you should only use channel 1, 6, 11 on the 2.4ghz.  Looks like you also have channel 5 and 13.
Scott
-Scott
Highlighted
Hall of Fame Master
One thing to note also in a mixed environment with 802.11n and non 802.11n access points.  802.11n clients will prefer to always roam to an 802.11n access point, thus may never try to roam to a non 802.11n access point until it drops.  Keep that in mind since I don't know how your environment is.  You are better off keeping all 802.11n aps together and non 802.11n aps together.  If you do mix, then disable 802.11n.
Scott
-Scott
Content for Community-Ad
