681
Highlighted
Beginner
Setting up additional Cisco 1142 AP
I am in the process of deploying an additional Cisco 1142 AP into my network. I would like to set it up to be the same SSID as the first one, and be able to have laptops roam from AP to AP. I am simply trying to expand the current coverage of my wireless network. I have both APs mounted and access to both.
CISCOAP01 - 192.168.2.2
CISCOAP02 - 192.168.2.3
What do I need to do (configre) to make this happen? I am rather new with Cicso. I am using the web interface to setup the APs. The first one has been up and running for about a year now with no problems. Here is the config file if that helps. Thanks
version 12.4
no service pad
service password-encryption
hostname CISCOAP01
enable secret 5 $1$tnSs$0e9SFlxbMjocoevA5udaW/
no aaa new-model
dot11 syslog
dot11 ssid FEDCO
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 110B160A04060E1E547B78
username Cisco password 7 00271A150754
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid FEDCO
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.2.2 255.255.255.0
no ip route-cache
ip default-gateway 192.168.2.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
sntp server 192.168.2.249
sntp broadcast client
end
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Setting up additional Cisco 1142 AP
all you need to do is create the same SSID on your new AP. keep all the same ciphers and PSK and the clients should roam between them fine. You do t need any of the WLCCP commands as you are not doing 802.1x
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
2 REPLIES 2
Steve
Beginner
Awesome! Thank you for your quick responce! Much appreciated for a Cisco n00b like me!
Content for Community-Ad
August's Community Spotlight Awards
