12-05-2018 12:59 PM - edited 07-05-2021 09:32 AM
i have 4 cisco 1142 autonomous access point. with Catalyst 3560-X Series PoE+, i need to cover two floors with the same SSID.
is one AP as Access point and the other 3 as repeater will be a good solution ?
05-28-2020 07:45 PM
06-16-2020 11:35 PM
07-30-2020 10:14 PM
Nice info, I love the way you express words with emotions. https://cokeclear.com/
12-28-2018 10:45 AM - edited 12-28-2018 10:46 AM
If you change your switch to Cisco 3850 or 3650 then you will be able to use converged access as these switches can also act as mobility controller. Or just get cheap cisco 2504 wireless controller on ebay. You can setup all access points in the same mobility domain with single single SSID and have seamless roaming between all access points.
