Some clients get a 0.0.0.0 address on the WLC
AndrewDeeker
Hi Guys,
I have a problem that I need some advice on please.....
On my WLC 5508 I see some clients that don't get a IP address. (See pic1)
These clients also have "DHPC_REQD status in their Policy Manager State. (See pic3)
As I said some clients.... Some work ok... (See pic1 / pic3)
My WLC is running version 7.6.130.0.
DHCP is coming from a Local windows DHCP server.
These devices do not have a static address.
Thanks Guys.
PIC1:
PIC2:
PIC3:
8 Replies 8
Under WLAN > Advanced tab, have you ticked "DHCP Address Assignment" option ? If not try to tick that and see.
Rasika
Hi Mate,
Thanks for the tip, but from what I read... this option will stop clients with a static address from working..
But what I'm seeing, is some clients on a AP have this problem and others on the same AP do not. ???
Regs Chris
abwahid
Level 4
Level 4
Please make sure the IP pool which you configured on the DHCP server has enough Address space.
& please mention your AP model as well so we may further check the root cause.
Thanks abwahid - yes, plenty of address space free in the DHCP scope being distributed.
We have a mix of AP's in the Infrastructure:
1131
1242
2602 (these are in use in the area causing concern)
were you able to get a fix for this ?
I had the same issue and it turned out to be a DHCP enrollment certificate that had expired on the DHCP server. Users in specific SSIDs were not getting IP's and therefore showing 0.0.0.0 because they were using a different certificate that had expired.
