07-13-2015 08:41 PM - edited 07-05-2021 03:34 AM
Hi Guys,
I have a problem that I need some advice on please.....
On my WLC 5508 I see some clients that don't get a IP address. (See pic1)
These clients also have "DHPC_REQD status in their Policy Manager State. (See pic3)
As I said some clients.... Some work ok... (See pic1 / pic3)
My WLC is running version 7.6.130.0.
DHCP is coming from a Local windows DHCP server.
These devices do not have a static address.
Thanks Guys.
PIC1:
PIC2:
PIC3:
07-13-2015 11:13 PM
Under WLAN > Advanced tab, have you ticked "DHCP Address Assignment" option ? If not try to tick that and see.
Rasika
07-15-2015 02:52 PM
Hi Mate,
Thanks for the tip, but from what I read... this option will stop clients with a static address from working..
But what I'm seeing, is some clients on a AP have this problem and others on the same AP do not. ???
Regs Chris
07-15-2015 02:56 PM
07-15-2015 03:01 PM
07-29-2015 01:19 AM
Please make sure the IP pool which you configured on the DHCP server has enough Address space.
& please mention your AP model as well so we may further check the root cause.
07-29-2015 03:38 PM
Thanks abwahid - yes, plenty of address space free in the DHCP scope being distributed.
We have a mix of AP's in the Infrastructure:
1131
1242
2602 (these are in use in the area causing concern)
02-17-2020 05:08 PM
01-10-2022 02:19 AM
I had the same issue and it turned out to be a DHCP enrollment certificate that had expired on the DHCP server. Users in specific SSIDs were not getting IP's and therefore showing 0.0.0.0 because they were using a different certificate that had expired.
