01-31-2012 02:46 AM - edited 07-03-2021 09:28 PM
Dear all,
I am using the WLC with version 7.0.116.0 and found that there are foot note mention that "
MAC Filtering is not supported with HREAP Local authentication" in WLAN configuration page,
Does it mean that MAC filtering does not support in HREAP local authentication?
Thanks.
Solved! Go to Solution.
01-31-2012 05:00 AM
That is correct... when the h-reap ap is in local authentication or stand alone mode, the mac filteing is bypassed, since the wlc has the mac filter list.
01-31-2012 05:00 AM
01-31-2012 06:49 PM
Thanks Scott,
Is there any documents to record the issue, thanks?
01-31-2012 06:56 PM
The documents on h-reap just state the same thing. The reason Mac filter works is because traffic flows to the wlc. So when you loose the connection to the wlc and the h-reap ap goes into standalone, there is no way to perform Mac filtering because the ap does not know of the Mac address. Makes sense?
Scott Fella
Sent from my iPhone
10-24-2012 08:27 AM
Can you confirm that you mean when the AP is in "AP mode: local" that MAC filtering will not work? Or does the "AP mode" need to be H-REAP for mac filtering to not work?
10-28-2012 02:05 PM
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080b3690b.shtml
Security - Client
Depending on the modes and states, security support on the FlexConnect varies. This table summarizes the security features supported.
WAN Up (Central switching) | WAN Up (Local Switching) | WAN Down (Standalone) | |
Open/Static WEP | Yes | Yes | Yes |
WPA-PSK | Yes | Yes | Yes |
802.1x (WPA/WPA2) | Yes | Yes | Yes |
MAC Authentication | Yes | Yes | No |
CCKM Fast Roaming | Yes | Yes | Yes, for connected clients. No, for new clients. |
