10-13-2018 08:24 AM - edited 07-05-2021 09:18 AM
Hi, does anybody knows if it is possible to start a ssh session from WLC to AP, I cannot find the proper command, I only have CLI access to WLC.
thanks
10-13-2018 08:28 AM
10-13-2018 08:55 AM
10-13-2018 02:01 PM
You can do ssh as long as the AP has joined the WLC and is currently in the RUN state. You also have to allow ssh from the WLC Wireless Configuration page. If the AP not joined or not joining the WLC, then use console into the AP and look what is wrong ?
WLC SSH config
Wireless - Global Configuration - set login creds
then choose All AP - choose AP - Advanced Tab - enable SSH
