10-10-2018 03:03 AM - edited 07-05-2021 09:16 AM
Hello ;
I went to deploy I hidden SSID With special characters like this : ‡users
the issue is Windows can't connect to this SSID .
I try to add it manuel but not work .
can you help me to correct this issue.
10-10-2018 03:14 AM
10-10-2018 03:32 AM
Hello ;
But it's work on windows 10 with Hidden SSID with special characters and not on windows 7
10-10-2018 04:04 AM
You will also want to consider passwords with special characters as well. I have had issues where the same password was being used on multiple devices. One of the devices would not join the wireless SSID because of some special characters in the password.
You can always verify that you have the latest drivers. However, is it really worth the hassle? You may just want to change the SSID so that it does not have any special characters.
Please mark helpful posts.
10-10-2018 04:07 AM
Hello
i try all special characters no one work .
10-10-2018 06:21 AM
Remove all of the special characters.
10-10-2018 07:00 AM
I need to put special characters to make the thing hard
10-10-2018 08:01 AM
10-10-2018 04:01 AM
@Leo Laohoo wrote:
Hidden SSID is no longer "safe". Hackers will consider it as a "challenge".
Do you have some more information on this?
10-10-2018 02:16 PM - edited 10-10-2018 02:19 PM
A lot of publications no longer recommend hidden SSID as a safe haven.
"hard" for who? The clients?
Creating an SSID based on PSK is easy for anyone to join because everyone knows the key. On the flip side, changing the key won't be straightforward because one the key is changed, EVERYONE gets affected.
As what Scott has said, use 802.1x and trusted certificates makes administrating the SSID a lot easier because passwords are based on the login.
10-10-2018 02:22 PM
10-11-2018 02:00 AM
Hi ;
i have already used 802.X with trusted certificates with ISE 2.4 but my manager toled me to hidden wireless with special characters to be more secure .
this why I went to do this .
10-11-2018 03:04 AM
This only proves that just because your manager told you doesn't mean he knows everything. It is your job to tell him it isn't going to happen because it isn't going to work.
10-11-2018 03:54 AM
