SSID to AD Group mappings in ACS 5.3
Hi ;
           I am trying to implement PEAP authentication with ACS 5.3. I have two SSID's with peap authentication and i have two groups in AD. I need to map one ssid with one group and another SSID with the other group.
Can any one tell me how to perform that. Also I appriciate if any one have best practice document for that.
Thank you
Scott Fella
You first need to create an end station filter for each of the ssid's.  This way in your authorization policy, you can define what ssid should match.
Example below is an SSID named PEAP.  You need to use the '*' as a wildcard.
On you Authorization policy, you can hit customize on the lower right side and choose what you want to try to match.
Here is the policy
-Scott
Thank you Scott.
I will try it on Monday and let you know if I need more help.
No problem.
-Scott
