Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
Ask Me Anything – How to Enable Network Connectivity to Remote Workers
424
Highlighted
Participant
Support for dACL at WLC
Is there any plan to support dACLs in the WLC?
As far as I know, SGACLs are supported, right? What's the difference between both if, in the end the SAGCLs implement filters based on destination ports, the IP addressing?
Regards.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Highlighted
VIP Mentor
Re: Support for dACL at WLC
On the traditional WLCs (85xx,55xx,35xx,25xx), you have to locally define those ACL in order to call as part of AAA override. This is mainly due to AireOS running on WLC as oppose to IOS/IOS-XE on switches.
Newer WLCs, (9800 series) is based on IOS-XE, so you should have same capability as any other 9000 series catalyst
Rasika
*** Pls rate all useful responses ***
2 REPLIES 2
Highlighted
VIP Mentor
Rasika
Highlighted
Participant
Thank you Rasika.
I will check the capabilities of the new 9800 series.
Content for Community-Ad
Cisco COVID-19 Survey
