TFTP broken in PI 1.x because of iptables
patoberli
Hi All
I recently upgraded our PI 1.2.1 to 1.3. It all worked fine but I had no more TFTP working. It didn't really work in the previous version, but now it didn't work at all. I could neither put nor get a file.
So today I checked out some system setting and finally found the reason within iptables.
Please note, this requires root access to the PI 1.3
Here:
ade # tftp -v -c put /localdisk/defaultRepo/cpi1.domain.com_neu.csr cpi1.domain.com_neu.csr
(to) x.x.x.x
Connected to x.x.x.x (x.x.x.x), port 69
putting /localdisk/defaultRepo/cpi1.domain.com_neu.csr to x.x.x.x:cpi1.domain.com_neu.csr [netascii]
Transfer timed out.
So this is the error message when doing it on the root shell. This error always appeared.
Now disabling iptables and doing it again:
ade # /etc/init.d/iptables stop
Flushing firewall rules: [  OK  ]
Setting chains to policy ACCEPT: filter [  OK  ]
Unloading iptables modules: [  OK  ]
ade #
ade #
(to) x.x.x.x
Sent 1062 bytes in 0.0 seconds [394426 bit/s]
And bang, it worked on the first try!
And reenabling iptables:
ade # /etc/init.d/iptables start
Applying iptables firewall rules: [  OK  ]
Anybody else also having those problems?
I'm sadly an absolute iptables beginner and don't really know how to troubleshoot this more (even though I expect it to be working from start).
Patrick
11 Replies 11
Scott Fella
I have always used FTP to upload a file to PI.  Have to looked at this doc?
https://supportforums.cisco.com/docs/DOC-26972
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Thanks for the link. I can't use FTP here, it has to be TFTP.
Well you can always try to patch or upgrade by using a tftp repository. I know it was broke, but I don't remember what code, but its worth trying.
TFTP Repository:
# configure
(config)# repository wcs-tftp-repo
(config-Repository)# url tftp://ip-address
(config-Repository)# exit
(config)# exit
-Scott
Also doesn't help.
But I found now a working solution. It indeed seems to be a wrong configured iptables. The issue is with the dynamic high-ports of TFTP which aren't allowed by default on iptables.
Here I found the hint that works: http://nartax.com/2012/04/iptables-rule-for-tftp/
So I logged in as root, edited the config file
vi /etc/sysconfig/iptables-config
And changed
IPTABLES_MODULES=""
to
IPTABLES_MODULES="ip_conntrack_tftp"
After saving it with :wq I restarted iptables and also restarted ncs (this is needed as some iptables rules are loaded when ncs starts and are lost when iptables is restarted!).
I'm checking if I can open a TAC case for this, so it might get fixed in some future version.
Patrick
[edit]
Can't open a TAC, my permission level is not enought
Message was edited by: Patrick Oberli Added comment about TAC
Yeah... Well we shall see:). The MSE also has issues with the iptables and I just usually do a flush and restart.
-Scott
Stop IPTABLES with "service iptables stop"
Edit /etc/sysconfig/iptables-config
Add ip_conntrack_tftp to IPTABLES_MODULES="" line so it reads
Start IPTABLES with "service IPTABLES start"
Please Let me know how it goes.
Make sure to rate correct answers
Thanks for your reply. As you can see in my reply just 10 minute before yours, I came to the same solution
Could you maybe create a Service Request for this as I don't have the permission?
Thanks a lot
Seems the bug already was existing. I searched for tftp in bug toolkit, but didn't receive a result.
Scott Fella
So I use FTP so this doesn't really affect me. What patoberli I think was stating, is if this is something the Cisco needs to add to the iptables so that it isn't a manual process. Patoberli did find out what needs to be changed though but doesn't have a support contract to maybe follow up to have this added.
-Scott
