07-25-2019 12:31 AM - edited 07-05-2021 10:45 AM
I need a help.
I configed 3504 to HA
If HA completed, the manament ip will be one ip address.
I have a SNMP collect server. the snmp server will add wlc ip address.
which ip address should i do? (When HA is complete, the snmp is not active from service port ip)
I'd like to collect snmp information from each wlc (Active and Standby)
07-25-2019 03:33 AM
- You need to use the management IP of the primary. You can snmp query it as to whether it is the primary node in the HA environment. I usually combine this with checking it's serial number in my monitoring system. Both parameters will tell me if there has been a takeover (or other abnormal conditions). You can not monitor starts from the standby node in a HA environment.
But there are lost of stats which can be obtained from the Primary node ; below is an example.
| OK | 07-25-2019 12:26:57 | 15d 12h 23m 9s | 1/20 | SNMP OK - true(1) | |||||||
| OK | 07-25-2019 12:25:51 | 43d 12h 26m 6s | 1/20 | SNMP OK - 3 | ||||||||
| OK | 07-25-2019 12:24:57 | 94d 19h 22m 59s | 1/2 | SNMP OK - Cisco Controller | ||||||||
| OK | 07-25-2019 12:27:52 | 235d 13h 52m 0s | 1/2 | SNMP OK - 525 | ||||||||
| OK | 07-25-2019 12:28:23 | 169d 12h 38m 31s | 1/2 | SNMP OK - 170 | ||||||||
| OK | 07-25-2019 12:26:52 | 235d 13h 56m 53s | 1/20 | SNMP OK - 415216 | ||||||||
| OK | 07-25-2019 11:53:12 | 1181d 1h 4m 59s | 1/20 | SNMP OK - 500 | ||||||||
| OK | 07-25-2019 12:25:52 | 43d 12h 26m 28s | 1/20 | SNMP OK - up(1) | ||||||||
| OK | 07-25-2019 12:25:54 | 235d 13h 55m 19s | 1/20 | SNMP OK - up(1) | ||||||||
| OK | 07-25-2019 11:36:03 | 1181d 0h 49m 56s | 1/20 | SNMP OK - true(1) | ||||||||
| OK | 07-25-2019 12:23:56 | 35d 15h 54m 43s | 1/20 | SNMP OK - true(1) | ||||||||
| OK | 07-25-2019 12:23:40 | 15d 12h 23m 26s | 1/2 | SNMP OK - 1443 | ||||||||
| OK | 07-25-2019 12:28:09 | 35d 15h 53m 39s | 1/20 | SNMP OK - "cloaked" | ||||||||
| OK | 07-25-2019 12:25:31 | 29d 12h 24m 43s | 1/20 | SNMP OK - "8.2.170.0" | ||||||||
| OK | 07-25-2019 11:27:29 | 735d 1h 21m 7s | 1/20 | SNMP OK - 377 | ||||||||
| OK | 07-25-2019 12:27:21 | 43d 12h 26m 16s | 1/20 | SNMP OK - enable(1) | ||||||||
| OK | 07-25-2019 12:27:23 | 29d 12h 24m 52s | 1/20 | SNMP OK - enable(1) |
08-01-2019 09:39 PM
08-06-2019 01:14 AM
08-06-2019 02:24 AM
The available information is limited and depending on the version of code, but it it correct that you need to use the management IP of the active HA-SSO unit to request information about the standby HA-SSO unit. More information can be found here. For the bigger appliances, based on UCS hardware, we normally use the CIMC interfaces to gather more information.
Please rate useful posts... :-)
09-07-2020 06:15 PM
You can monitor following details of redundant WLC after WLC 8.7 code and above.
Article :- https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-7/High_Availability_DG.html
