6663
Beginner
Re: Trying to get AIR-AP1562I-E-K9 to Join WLC
Thanks again for your reply
Here are the results from the AP
sh ip interface brief
Interface IP-Address Method Status Protocol Speed
wired0 10.13.1.65 DHCP up up 1000
wifi0 n/a n/a up up n/a
wifi1 n/a n/a up up n/a
We do have a time server - Sorry My Copy/Paste did not get it all.
(Cisco Controller) >show time
Time............................................. Wed Aug 30 13:17:23 2017
Timezone delta................................... 0:0
Timezone location................................ (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
NTP Servers
NTP Polling Interval......................... 600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 217.116.227.3 In Sync AUTH DISABLED
It made no difference whit this command.
"capwap ap primary-base <CONTROLLER NAME> <CONTROLLER IP ADDRESS>"
Johnni
Hall of Fame Community Legend
The IP address of the AP and the WLC are on different subnets. Can the AP ping the Management IP address of the controller?
Highlighted
Beginner
Thanks for your reply
Nice Catch.....
But yes the are abel to See eachother - We do have more subnets - But ALL the 800 AP, is located on the same net.
I did test the Switch I am trying to connect to AP to whit a 2802I (our new choice of AP) - That one goes online, and have no trouble Connecting to my WLC, and are being shown in my Prime.
So the problem is whit the AP1562I as I see it.
VIP Mentor
Are you sure that you add the AP mac addess on WLC?
Complete these steps:
  1. From the WLC controller GUI, click Security > AP Policies. The AP Policies page appears.
  2. Click the Add button on the right hand side of the screen.
  3. Under Add AP to Authorization List, enter the AP MAC address.
 Still fail then please paste the complete bootup process from  Cisco AP Console.
Dont forget to rate helpful posts
What "white list"?  I have 1562I/D in my network and I didn't put any white list.
I just enabled DHCP Option 43 and off they went.
Beginner
Hi there ,
Looks like this model is still in the mesh mode and u may need to first convert it to local mode. Can u provide the output of "show capwap client config command" from the AP ?
Ideally , for the mesh mode Aps to join the WLC, you need to first configure the MAC of the AP in the auth-list in the WLC. Security >> AP policies >> auth list
However , there is also a way to convert the mesh AP to local mode from the AP cli and then make it join the WLC. I am assuming that you don't have the intentions of using this Ap in mesh mode.
Manish
Beginner
Please can this model of AP be in standalone Mode 1562i ? please pardon my ignorance.
do i order with this = SWAP1560-LOCAL-K9
VIP Mentor
Please always create a new thread for new question.
Yes it can work as standlaone (Mobility express) AP.
Here is the software for it:
https://software.cisco.com/download/release.html?mdfid=286290657&flowid=82045&softwareid=286289839&release=8.5.120.0&relind=AVAILABLE&rellifecycle=&reltype=latest
Beginner
I am yet to order the AP I can see I have 3 software options to choose from.
VIP Mentor
Update: you must order:
Hardware: AIR-AP1562I-x-K9 with Software option: SWAP1560-MBEXP-K9
Beginner
Thanks mate
Beginner
I noticed in reading the release notes for the earlier version that the AP1562I had to manually upgraded in order to connect to the controller.  I wonder if this may be the same issue for you...
I also came across an article that mentioned the AP booting up in Mesh mode and not connecting to the Controller...
I think that is about all i can think of...
Hope you get some help... I am curious what the answer is to this.
Beginner
Last time and i'll stop guessing...
Where you added the MAC address is there a checkbox that says "Accept Manufactured Installed Certificate (MIC).
Can you check it and apply and see if that corrects your issue.
Beginner
I too have this exact problem.
No, the MIC thing doesn't work.
No, adding that wlc address manually doesn't work.
It looks like I will have to manually downgrade the software on the 1562I.
Mal.
Beginner
My AP didn't join WLC too, untill I did two things:
1. Added AP's MAC address to the filter at Security tab
2. Installed AP BUNDLE in addition to my image
Content for Community-Ad
July's Community Spotlight Awards
