02-12-2019 06:10 AM - edited 07-05-2021 09:50 AM
I need to set up a universal workgroup bridge access point on a mobile forklift. My issue is the customer would like to use a username and password combination for authentication on the wireless network that the workgroup bridge access point will be connecting too. Is it possible to set up the workgroup bridge to authenticate with a username and password?
Solved! Go to Solution.
02-12-2019 11:45 PM
You can configure the WGB to connect via PSK or 802.1x
Note this is with the WGB connecting to a WLC based AP.
Example using PEAP auth (username and password)
02-12-2019 11:53 PM
If you are using wlc then use this link to configure the AP as WGB:
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/68472-configure-wgb-00.html
WGB with autonomous AP:
https://mrncciew.com/2018/05/25/wgb-with-peap/
Dont forget to rate helpful posts
02-12-2019 11:48 AM
Hi.
Take a look here. Section "Configuring Workgroup Bridge Mode"
-If I helped you somehow, please, rate it as useful.-
02-12-2019 11:45 PM
02-13-2019 04:39 AM
02-12-2019 11:53 PM
