03-20-2019 01:45 PM - edited 07-05-2021 10:05 AM
I am hoping to upgrade the WLCs - listed below by revision and model - to v 8.5.131. Can they all be upgraded directly to the new version? Or is an intermediary version required to be in place first before jumping to 8.5.131?
7.6.130.0 | 2500 |
7.6.130.0 | 2500 |
7.6.130.0 | 5500 |
7.6.130.0 | 5500 |
7.6.130.0 | 5500 |
7.6.130.0 | 5500 |
7.6.130.0 | 5500 |
7.6.130.0 | 2500 |
8.0.140.0 | 2500 |
8.0.140.0 | 2500 |
8.0.140.0 | 2500 |
8.3.141.0 | 5500 |
8.3.141.0 | 2500 |
8.3.141.0 | 5500 |
Solved! Go to Solution.
03-20-2019 02:25 PM
Firstly the TAC recommended version in 8.5.x is 8.5.140.0
The Upgrade path to 8.5 is:
From the 8.5 release notes: https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85mr3.html
You can not upgrade directly to 8.5.x if you are running 8.2.12x or earlier
Its recommended first upgrading to 8.2.16x or 8.3x
We then need need to check 8.2.17x release notes:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82mr7.html
Which it says can go straight from 7.6.x
Make sure you check the https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html to ensure all your APs will be supported on the 8.5.x train.
03-20-2019 02:25 PM
Hi @Michael Medwid ,
Check the table that indicates this guide:
Table 3. Upgrade Path to Cisco WLC Software Release 8.5.131.0Current Software ReleaseUpgrade Path to 8.5.131.0 Software
8.2.16x.0 and later | You can upgrade directly to Release 8.5.131.0
8.3.x.0 | You can upgrade directly to Release 8.5.131.0 | ||
8.4.100.0 | You can upgrade directly to Release 8.5.131.0 |
Note | If you are using Release 8.2.15x or earlier, we recommend that you upgrade to Release 8.2.16x or 8.3.x and then upgrade to Release 8.5.131.0. |
I leave the link for more detail:
I hope it's useful for you.
03-20-2019 02:25 PM
03-20-2019 03:05 PM
03-20-2019 02:25 PM
