Upgrade considerations - directly to 8.5.131.0 - 2500s and 5500s?
Michael Medwid
I am hoping to upgrade the WLCs - listed below by revision and model - to v 8.5.131. Can they all be upgraded directly to the new version? Or is an intermediary version required to be in place first before jumping to 8.5.131?
7.6.130.0 2500
7.6.130.0 2500
7.6.130.0 5500
7.6.130.0 5500
7.6.130.0 5500
7.6.130.0 5500
7.6.130.0 5500
7.6.130.0 2500
8.0.140.0 2500
8.0.140.0 2500
8.0.140.0 2500
8.3.141.0 5500
8.3.141.0 2500
8.3.141.0 5500
2 Accepted Solutions
Haydn Andrews
Firstly the TAC recommended version in 8.5.x is 8.5.140.0
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc12
The Upgrade path to 8.5 is:
From the 8.5 release notes: https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85mr3.html
You can not upgrade directly to 8.5.x if you are running 8.2.12x or earlier
Its recommended first upgrading to 8.2.16x or 8.3x
We then need need to check 8.2.17x release notes:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82mr7.html
Which it says can go straight from 7.6.x
Make sure you check the https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html to ensure all your APs will be supported on the 8.5.x train.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
luis_cordova
Hi @Michael Medwid ,
Check the table that indicates this guide:
Table 3. Upgrade Path to Cisco WLC Software Release 8.5.131.0Current Software ReleaseUpgrade Path to 8.5.131.0 Software
8.2.16x.0 and later
You can upgrade directly to Release 8.5.131.0
Note
Release 8.2.16x.0 is affected by CSCvf12068.This issue is addressed by upgrading to 8.5.131.0.
8.3.x.0
8.4.100.0
Note
If you are using Release 8.2.15x or earlier, we recommend that you upgrade to Release 8.2.16x or 8.3.x and then upgrade to Release 8.5.131.0.
I leave the link for more detail:
I hope it's useful for you.
Haydn Andrews
Thank you very much.
luis_cordova
8.2.16x.0 and later
Note
8.3.x.0
8.4.100.0
Note
