03-21-2019 07:08 AM - edited 07-05-2021 10:06 AM
I'm currently required to upgrade a 2504 from 8.0.140.0 to 8.3.143.0 to support some 3802i's that are being added. I see the minimum required FUS is 1.9. The website says to upgrade the FUS first and then when the controller is back up to upgrade the firmware. I've also heard it's better to upgrade the controller to 8.3 first and then upgrade the FUS. Is either order fine? I'll be doing this in an extended maintenance window but I'll be remote so want to be prepared.
Solved! Go to Solution.
03-21-2019 07:14 AM
yes either order is fine. Also you can upgrade to 2.0 directly.
Make sure you take a min of 45-60 min downtime window for FUS upgrade .
Dont forget to arte helpful posts
03-21-2019 07:14 AM
03-21-2019 09:38 AM
03-22-2019 11:29 AM
Upgraded the controller to 8.3 and the FUS to 2.0 last night w/o any issues. Connected the 3802 (both E and I ) this morning but they're not joining the controller. When I check cdp I see the devices are running 8.5.131. Do i need to upgrade to at least that version on the controller or should the APs downgrade to 8.3? They're getting dhcp and are on the same vlan as the existing APs so they are getting option 43.
03-25-2019 03:27 AM
03-25-2019 04:06 AM
set the correct time on WLC!!!
03-25-2019 06:08 AM
WLC is getting time via NTP and it is correct.
03-25-2019 06:23 AM
WLC: sh sysinfo
AP: sh version
Paste the complete bootup process from AP console.
Reggards
Dont forget to rate helpful posts
03-25-2019 07:22 AM
03-25-2019 08:00 AM - edited 03-25-2019 08:00 AM
This looks fine.
Do you see any messages in the WLC logfile of the joining APs?
03-25-2019 08:27 AM - edited 03-25-2019 09:12 AM
No, I didn't see anything when I looked Friday. If i do a show power inline as the device is coming up it show as a AIR-AP3802E-B-K9, but after a few minutes it shows as IEEE. The device comes up in CDP for a few minutes, then disappears. The MAC address drops out of the switch table a few minutes after the AP is power cycled as well.
TDR test looks good for the cable as well. The APs require a lift to access so getting to them to get the console logs would need to be scheduled.
Tried a debug capwap events on the controller but not seeing any information displayed on in the logs.
03-25-2019 09:30 AM
03-25-2019 01:40 PM
Going onsite in the morning to get console access to an AP. Possible they were shipped w/ Mobility Express software and that's the issue?
03-26-2019 12:56 AM
03-26-2019 01:10 PM
Yes, these were brand new out of the box, upgraded controller to gain support for the 3802s. Turns out they were running ME image so had to go onsite and convert them.
Thanks for all the help!
