Upgrade IOS for a 3802i with USB Key
kevinmelka1
I have a question regarding the 3802i Cisco Aironet.
Indeed, there is a usb port behind the AP and my question is the following one :
It's possible to upgrade the IOS of the 3802i Cisco Aironet thanks to a USB Key ?
Thanks in advance for your return.
Best regards.
Kevin M
2 Accepted Solutions
Scott Fella
The answer is no.
-Scott
Leo Laohoo
8 Replies 8
Scott Fella
The answer is no.
-Scott
Leo Laohoo
Not possible.
Thanks for your answer guys :) !
I tested to upgrade the AP with a TFTP Server but it didn't work nonetheless i deactivated the Windows firewall and my antivirus :(.
Do you know another way to do it ?
Thanks in advance for your answer.
Best regards.
Kevin MELKA
What command did you use?
I used TFTP64 server but it's not really user friendly :s.
Do you know another TFTP server solution which is great except TFTP64 and TFTP Solarwinds ?
To answer to your question, i used this documentation to do it :
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/107911-ios-upgrade.html
If you have another one, it would be great :).
Thanks in advance.
Best regards.
Kevin M
TFTP64 & Solarwinds are de facto "standard" and recommended.
Can you try running TFTPd64 on a different machine?
The command "archive download-sw tftp://TFTP_IP_ADDRESS/filename.tar" is what should be used.
What error messages are you getting when you try the above command?
I tried to do the command but i have nothing.
What is the procedure to upgrade the IOS of a Cisco AP (in this case 3802i) ?
Thanks in advance for your help.
Best regards.
Kevin M
What IOS are you trying to upgrade?  The CAPWAP image or Mobility Express image?
