09-26-2013 03:45 PM - edited 07-04-2021 12:57 AM
I can't for the life of me find an answer but I thought there was some extra "notes" for upgrading two 5508 controllers in a mobility group. I have about 150 AP's (1140 series) and would really like to minimize the downtime as much as possible. My current plan is as follows:
Upgrade WLC-2 (the secondary)
Reboot WLC-2
Upgrade WLC-1 (Primary w/all the AP's attached)
Push the AP image {predownload primary all}
Wait for the push to finish
Reboot WLC-1
Any tech notes / real life lessons learned you can share would be great. It's a Hospital so I need to keep the downtime to an absolute minimum.
Going from 7.0.116 to 7.4.110
Todd
09-26-2013 04:01 PM
As long as you will not be going to implement HA SSO, 7.4.110.0 seems to be a good version. Although I haven't used this, some people have had good results with this version.
Your upgrade process is OK.
09-27-2013 12:07 PM
I was actually looking at HA to keep the configs in sync. Are there problems with it?
09-27-2013 04:20 PM
Not really.
I'm using 7.5 and I don't see any issues.
Have done multiple failovers of the AP during business hours and no one seemed to notice.
