User not getting authenticated/connected to WLAN (radius authentication )
pankaj.bandewar
Hello Experts,
I have one SSID which having RADUIS authentication but when client try's to connect it ..it fails ...
here are the logs from thecontroller.
Dot1x_NW_MsgTask_0: Nov 07 13:05:08.371: %DOT1X-3-INVALID_WPA_KEY_MSG_STATE: [PA]1x_eapkey.c:1002 Received invalid EAPOL-key M2 msg in START  state - invalid secure bit; KeyLen 40, Key type 1
*Dot1x_NW_MsgTask_0: Nov 07 13:04:56.767: %DOT1X-3-AAA_AUTH_SEND_FAIL: [PA]1x_aaa.c:849 Unable to send AAA message for client 90:2e:1c:47:e7:80
*Dot1x_NW_MsgTask_0: Nov 07 13:04:56.765: %DOT1X-3-ABORT_AUTH: [PA]1x_bauth_sm.c:450  Authentication Aborted for  client 90:2e:1c:47:e7:80 Abort Reason:DOT1X RESTARTED DUE TO EAPOL-START/CLIENT ROAM
19 Replies 19
pankaj.bandewar
Hello experts,
kindly someone share the resolution for the same.
Which version you are running on WLC ?
Which WLC model you are using ?
How is your seup ?
Dont forget to rate helpful posts
8.2.151.0
5508
How is your seup ?
Radius Servers are in US and reachable via MPLS and S2S Tunnel also.
I have tried by changing the advanced eap bcast-key-interval to 86400 from default 3600 but issue is still there.
I also unchecked
Enable Session Timeout
but this is also not worked ..
Now this is getting serious issue and 10+ users are already affected from this.
only few clients are having issues or its with all clients ?
paste the output of the command: sh wlan <id>
Please make sure shared key between WLC and RADIUS server is the same.
BR,
John
= Same only..
Got anything Sir...Anyone..
I think:
you must be hitting a bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuu15866/?referring_site=bugquickviewredir
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuw37942/?referring_site=bugquickviewredir
Unlikely..Users are getting disconnected and we need to manually re connect to the SSID this is non frequent in nature and random occurring issue..
Dear Sir,
Did not able to find the bug in the release notes 8.2.151.0 .
Can you please guide further . i have upgraded the drivers of the laptop to the latest Intel 19.60 release but issue still persists.
up to 20 Clients Not all.
(Cisco Controller) >show wlan 2
WLAN Identifier.................................. 2
Profile Name..................................... GLOBALACCESSII
Network Name (SSID).............................. GLOBALACCESSII
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Disabled
     DHCP ....................................... Disabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
--More-- or (q)uit
ATF Policy....................................... 0
Number of Active Clients......................... 122
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 720 minutes
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... none
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ pune_main_office
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Tunnel Profile................................... Unconfigured
PMIPv6 Mobility Type............................. none
--More-- or (q)uit
    PMIPv6 MAG Profile........................... Unconfigured
    PMIPv6 Default Realm......................... Unconfigured
    PMIPv6 NAI Type.............................. Hexadecimal
    PMIPv6 MAG location.......................... AP
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
--More-- or (q)uit
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... 802.1P (Tag=0)
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ 151.171.47.224 1812 *
   Authentication................................ 151.171.47.215 1812 *
   Authentication................................ 10.106.3.59 1812 *
   Accounting.................................... 151.171.47.224 1813 *
   Accounting.................................... 151.171.47.215 1813 *
   Accounting.................................... 10.106.3.59 1813 *
      Interim Update............................. Enabled
      Interim Update Interval.................... 0
      Framed IPv6 Acct AVP ...................... Prefix
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Radius NAI-Realm................................. Disabled
Mu-Mimo.......................................... Enabled
Security
--More-- or (q)uit
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
      OSEN IE.................................... Disabled
      Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
         OSEN-1X................................. Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Disabled
      GTK Randomization.......................... Disabled
--More-- or (q)uit
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web Authentication Timeout.................... 300
   Web-Passthrough............................... Disabled
   Mac-auth-server............................... 0.0.0.0
   Web-portal-server............................. 0.0.0.0
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Enabled
   FlexConnect Central Association............... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
--More-- or (q)uit
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
   Eap-params.................................... Disabled
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flex Avc Profile Name............................ None
Flow Monitor Name................................ None
Split Tunnel Configuration
    Split Tunnel................................. Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
802.11v Directed Multicast Service............... Disabled
802.11v BSS Max Idle Service..................... Enabled
802.11v BSS Transition Service................... Disabled
--More-- or (q)uit
802.11v BSS Transition Disassoc Imminent......... Disabled
802.11v BSS Transition Disassoc Timer............ 200
802.11v BSS Transition OpRoam Disassoc Timer..... 40
DMS DB is empty
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Universal Ap Admin............................... Disabled
Mobility Anchor List
WLAN ID     IP Address            Status                             Priority
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority  Policy Name
Lync State ...................................... Disabled
--More-- or (q)uit
Audio QoS Policy................................. Silver
Video QoS Policy................................. Silver
App-Share QoS Policy............................. Silver
File Transfer QoS Policy......................... Silver
Hello @pankaj.bandewar
Did you find a solution to your problem? As i am having the same issue affecting few users only.
Was there any resolution too this?
I am running the same 8.2.151.0 on 5508 and WPA2. I am getting the exact same symptom. It is very random. I am curious as to what might have been done.
Thank You!
Well I did something Like this
1.Upgrade the NIC Card software version on Laptops.
2.Change the default epol key interval time to 24 hrs.
3.disable the session timeout.
4.enable the NAC state as : RADIUS NAC
5. Upgrade the IOS of Controller to Cisco Recommended ver.
resolved finally..
