Highlighted
Beginner
VPN-PassThrough with wlc 5508 7.0.235.0
HI, i have 2 ssid with the same comfiguration (diff only in name) in one ipsec ssid vpn (l2tp over ipsec with natt ) works fine, in another after phase 2 is completed no traffic is forwarded and vpn session is dropped.
There are no access lists on equipment.
I found in documentation that need to activate L3 security and set it to vpn pass-through, but in drop-down menu only one item "none".
What is the reason to drop ipsec traffic  ?
4 REPLIES 4
Highlighted
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70wlan.html#wpmkr1140732
Configure a WLAN for VPN passthrough using the controller CLI by entering this command:
•config wlan security passthru {enable | disable} wlan_id gateway
For gateway, enter the IP address of the router that is terminating the VPN tunnel.
Verify that the passthrough is enabled by entering this command:
•show wlan
I see the drop down showing vpn passthrough for 7.0.116.0 and the applicable cli.
Highlighted
(Cisco Controller) >config wlan security ?
802.1X         Configures 802.1X.
cond-web-redir Configured Conditional Web Redirect.
splash-page-web-redir Configured Splash-Page Web Redirect.
static-wep-key Configures static WEP keys on a WLAN.
web-auth       Configures Web authentication.
web-passthrough Configures Web Captive Portal with no authentication required.
wpa            Configures WPA/WPA2 Support for a WLAN
ckip           Configures CKIP Security on WLAN.
tkip           Configures TKIP MIC countermeasures hold-down timer (0-60 seconds)
passthru is mising here too, i will try to downgrade to
7.0.116.0
Highlighted
use code 7.0.116.0, what you're seeing is a bug and it require to fix. please open tac case and refer this link.
Highlighted
vpn passthrough is not a supported feature on 5500 based WLCs, however it does support on 4400/Wism1. It is a bug that gui and cli shows the feature configurations on unsupported platforms however using ACLs vpn passthrough is still supported.
http://www.cisco.com/en/US/partner/docs/wireless/controller/release/notes/crn7_2_111_3.html#wp786160
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70ovrv.html#wp1154082
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70wlan.html#wp1084908
The VPN Passthrough option is not available on Cisco 5500 Series and Cisco 2100 Series Controllers. However, you can replicate this functionality on a Cisco 5500 or 2100 Series Controller by creating an open WLAN using an ACL.
Content for Community-Ad
