Hello
I have 4 wap 351 in cluster (firmware 1.0.2.13) placed on a vlan, 2 ssid. Everything is working.
However I have 2 problems
1 / "channel isolation" is checked on the cluster, 2 pc logged on the same ssid can ping, 2 pc logged on a different ssid can also ping between them
2 / wap 351 appears in the "network neighborhood" on windows 7.
Are these behaviors normal?
Thank you for you help
