04-14-2011 07:14 AM - edited 07-03-2021 08:04 PM
Hi Guys,
For some reason overnight the WCS server can no longer reach the lan controllers.
They are on the same subnet and can ping both ways.
I tried deleting and re-adding but it still cannot find it.
I've tried rebooting everything and still doesnt work.
Anyone have ideas?
Solved! Go to Solution.
04-14-2011 07:34 AM
Whats the WLC software version?? SNMP configurations are correct?? wats does the logs say??
Surendra
04-14-2011 07:34 AM
Surendra
04-14-2011 07:45 AM
I upgraded the WLCs to the latest 7.0.98.218 to see if that was an issue. It was 7.0.98.0 previously. Doing this obviously made no difference.
I'll check SNMP but meanwhile which logfile do i check?
04-14-2011 07:49 AM
WCS logs..
WCS >> Adminstration >> loggings >> Traces >> Download
WCS 0.0.txt , what does it tell??
Surendra
04-14-2011 08:11 AM
audit-1] Configuration Sync for device 10.60.43.253 started.
04/15/11 01:00:00.410 INFO [monitor] [audit-2] Configuration Sync for device 10.60.43.254 started.
04/15/11 01:00:14.410 ERROR [communication] [audit-1] [10.60.43.253] Unable to reach the device: 10.60.43.253/161 using SNMP version v2
04/15/11 01:00:14.410 INFO [config] [audit-1] ConfigSyncHelper auditSwitchTree:+controllerObj.getDeviceIpAddress() com.cisco.server.common.errors.DeviceUnreachableException: MEDIATION-2,10.60.43.253/161
04/15/11 01:00:14.410 ERROR [communication] [audit-2] [10.60.43.254] Unable to reach the device: 10.60.43.254/161 using SNMP version v2
04/15/11 01:00:14.410 INFO [config] [audit-2] ConfigSyncHelper auditSwitchTree:+controllerObj.getDeviceIpAddress() com.cisco.server.common.errors.DeviceUnreachableException: MEDIATION-2,10.60.43.254/161
04/15/11 01:00:14.410 ERROR [general] [audit-1] THROW
So it looks like i'll focus on SNMP?
04-14-2011 08:19 AM
ok!!
Lemme know if u need any help..
Surendra
04-14-2011 08:38 AM
Thanks Surendra.
It was SNMP.
Some reason SNMP config was lost in the WLCs and since the snmp string is starred out in WCS i had to create a new string.
Then i had to delete the controllers from WCS and rediscover them with the new snmp string.
All works now!
Thanks for pointing me in the right direction. I thought WCS only talks via SSH as its more secure.
Thanks again! I'll give you a star! :-)
04-14-2011 09:52 AM
WOW!!
Thats nice to hear!! thanks for posting on CSC
Surendra
