01-18-2011 10:11 AM - edited 07-03-2021 07:41 PM
I have installed WCS 7.0 now i have installed Navigator on WCS server.
Installation is completed.
but when I check the status of WCS, it says "healthmonitor running with errors"
any one knows what could be the problem and how much will that effect on WCS performance ?
01-23-2011 09:19 AM
Stop ans Start the WCS again and see if we are still facing the same issue..
Surendra
01-27-2011 01:22 PM
Sur,
can you run Nav on a VM... say you have a small 2k ap and 10 WCS deployment ... ?
01-27-2011 10:34 PM
Hi Goerge,
Yes we can run NAV on a VM, we just need to make sure htat the hardware requirements are met..
Surendra
01-28-2011 02:51 PM
Sur,
Assume I have 10 WCSs and 2000 access points. I shouldnt need full specs, right. I mean it would be overkill. What is your thoughts?
01-28-2011 08:23 PM
Yup.. Using full spec is of no use.. Even i think the same as n i agree with you...
Surendra
09-03-2011 05:48 AM
Hello Kiran,
Please mark the Question as Answered, if the provided information by Surendra is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
