WCS - Rogue AP Un-containment
cchughes
I have an AP that was contained during testing. How do I un-contain it? Also, is it possible to get a listing of all Rogue AP's that have been contained?
I'm running Wireless Control System
Version 5.2.130.0
Thanks!
7 Replies 7
Lucien Avramov
Level 10
Level 10
you are most likely hitting bug : CSCsx16210 WCS: Incorrectly shows Rogue APs as contained
Disregard the message for now. Later release of WCS 5.2 and the following 6.0 release will have the fix.
You can acknowledge the alarm or change it's severity to be less bothered
No bug. I was testing containment with a spare AP. Now I cant use it because its contained.
Leo Laohoo
Monitor > Rogues > Malicious APs
The blue drop-down menu will allow you to remove from the list.
Which drop-down are you referring to...
Please check out the pic I attached. You have to hover your mouse over the little blue box on the right side and click 'Remove'.
What version is that? my screens dont look like that. I am running WCS 5.2.130.0
that is on the controller GUI itself.
