06-23-2011 09:27 AM - edited 07-03-2021 08:21 PM
WCS fails to start with a Tomcat error , see below ;
See launchout below - any ideas - without re-installing WCS
Checking for Port 21 availability... OK
Checking for Port 8456 availability... OK
Checking for Port 8457 availability... OK
Checking for Port 1299 availability... OK
Checking for local Port 1299 availability... OK
Checking for Port 6789 availability... OK
Checking for local Port 6789 availability... OK
Checking for UDP Port 69 availability... OK
Checking for Port 8005 availability... OK
Checking for UDP Port 162 availability... OK
Checking for Port 8009 availability... OK
Starting RMI registry on port 1299
Registry started.
DB is already started
Starting NMS Server...
NMS Server Started.
Starting up TFTP server...
TFTP Server started.
Starting up FTP server
Started FTP
FTP Server started
Apache server is already started
Starting Tomcat server ...
Tomcat server failed to start.
Failed to start the Tomcat web server.
Shutting down Apache server ...
Stopping FTP server...
Exception during ServerEngine::run java.net.SocketException: socket closed
at java.net.PlainSocketImpl.socketAccept(Native Method)
at java.net.PlainSocketImpl.accept(PlainSocketImpl.java:390)
Stopping TFTP server...
at java.net.ServerSocket.implAccept(ServerSocket.java:453)
at java.net.ServerSocket.accept(ServerSocket.java:421)
at ranab.server.ServerEngine.run(Unknown Source)
at java.lang.Thread.run(Thread.java:619)
Stopped TFTP server.
Stopped FTP server.
Failed to shutdown Apache server.
Leaving database server running.
06-23-2011 11:48 AM
Just curious, when did this problem start? Did it coincide with any recent Microsoft patches/updates?
06-23-2011 12:34 PM
unsure but i'll check
06-24-2011 11:01 PM
Have you rebooted the server? Ensure that other web applications running from third party such as IIS is disabled as this will cause a port conflict.
What OS is this installed on?
Post the logs from WCS7.0.164.0/webnms/logs in zip format.
WCS 7.0.172 is available for download which is recommended to upgrade to.
06-27-2011 01:17 PM
Hello!
I have exactly the same problem with WCS 7.0.172.
Fresh install, so I am open to any solution!
Rebooted the server - didn't help.
Re-installed WCS - didn't help.
Disabled McAfee security software - didn't help.
Create a new virtual machine (Win2k3) from template - I think this wouldn't help either.
Any other ideas?
Logs and systeminfo attached.
Best regards,
Andras
06-28-2011 02:05 AM
All I've resolved my issue - which is also in a VM environment - It was related to the available memory provided by VMware
06-28-2011 04:03 PM
Make sure you always have available memory and disk resources. There is a minimum systems requirement list for the size of deployment you own. See below.
Next, check the services running on the server to verify that the database and WCS have started on the machine. If this doesn't solve your problem then there are some database tools to check the integrity of the WCS Solid database. They are in the WCS directory of your server. These will allow you to know if you have a database issue. After these solutions have been exhausted I would open a TAC case.
06-15-2012 07:45 AM
Is you IIS service running at startup? If so try disabling that.
06-17-2012 11:29 PM
Netstat -a
Check if there is any other application using WCS ports, stop it and try again.
