Wifi client got IP from management interface of vWLC
Greetings,
   I got problem with vWLC:
    Cisco1861 as DHCP server
         Two DHCP Server Scope:
               ip dhcp pool BUFFALO
                    network 192.168.111.0 255.255.255.0
                    default-router 192.168.111.254
                    dns-server 192.168.111.254
             ip dhcp pool vWLC-TEST
                  network 192.168.30.0 255.255.255.0
                  default-router 192.168.30.254
                  dns-server 8.8.8.8
    vWLC as Wireless Controller
       Management interface 192.168.111.205
       Dynamic interface: 192.168.30.205
    AP: 3602i
Problem: wifi client always get ip from DHCP in management interface. My AP is in FlexConnect mode.
Screen Shot 2020-01-23 at 4.38.25 PM.pngScreen Shot 2020-01-23 at 4.38.40 PM.pngScreen Shot 2020-01-23 at 4.38.58 PM.pngScreen Shot 2020-01-23 at 4.39.22 PM.png
BRG
Tony
JPavonM
Have you configured the flexconnect profile?
https://community.cisco.com/t5/wireless-mobility-documents/wireless-lan-flexconnect-configuration-example/ta-p/3112924
-Jesus
*** Rate All Helpful Responses ***
I do configure Flexconnect profile. But after Flexconnect profile configure, client is unable to get ip from DHCP.
If your clients are getting an address from the central locations, its because you either don’t have local switching enabled on the WLAN, or. your plan to vlan mappings are incorrect.
-Scott
Jurgens L
Level 3
Level 3
Did you setup the SSID under advanced to do central switching? Since you are using a dynamic interface even though the AP is in flexconnect mode, you will need to switch the traffic centrally back to the WLC by setting up central switching on the SSID advanced tab under the FlexConnect configuration.
In most use cases the vWLC’s are used to configure SSID’s for local switching since it has limitied data throughput (500Mbps) and the vWLC can become a bottlenet if you have alot of traffic getting centrally switches back to the WLC.
https://www.cisco.com/c/en/us/products/collateral/wireless/virtual-wireless-controller/qa_c67-715130.html
