wifi is dropping on some of my clients, i have a Cisco 2504 Controller and 1852 AP's
KEVIN MCCOY
my version on the controller is 8.3.141.0 (default) (active)
i also increase eap bcast-key-interval from 3600 to 15000
looking through the Syslogs this is the erros showing up
please help
*Dot1x_NW_MsgTask_2: 1x_ptsm.c:544 Max EAPOL-key M1 retransmissions exceeded for client e8:p1:e9:o0:7a:d6
*apfReceiveTask: apf_ms.c:7398 Could not find the mobile e8:p1:e9:o0:7a:d6 in internal database
-cap-controller    Error    NY-WC-2504-01: *Dot1x_NW_MsgTask_6: 1x_ptsm.c:730 Client e8:p1:e9:o0:7a:d6 may be using an incorrect PSK
The syslogs show:
*Dot1x_NW_MsgTask_2: 1x_ptsm.c:544 Max EAPOL-key M1 retransmissions exceeded for client e8:c1:d9:00:7a:2a (Ipad 1)
    NY-WC-2504-01: *Dot1x_NW_MsgTask_2: 1x_ptsm.c:730 Client e8:c1:d7:00:7a:2a may be using an incorrect PSK
    1/8/2019 2:17:45 PM    cisco-capwap-controller    Warning    NY-WC-2504-01: *Dot1x_NW_MsgTask_2: 1x_ptsm.c:544 Max EAPOL-key M1 retransmissions exceeded for client e8:c1:d7:00:7a:2a (ipad 1)
    1/8/2019 2:17:41 PM    cisco-capwap-controller    Warning    NY-WC-2504-01: *Dot1x_NW_MsgTask_2: 1x_ptsm.c:544 Max EAPOL-key M1 retransmissions exceeded for client e8:c1:d7:00:7a:2a (ipad 2)
    1/8/2019 2:17:34 PM    cisco-capwap-controller    Warning   NY-WC-2504-01: *Dot1x_NW_MsgTask_6: 1x_ptsm.c:544 Max EAPOL-key M1 retransmissions exceeded for client e8:c1:d7:00:7a:b6 (ipad 3)
    1/8/2019 2:17:31 PM    cisco-capwap-controller    Warning  NY-WC-2504-01: *Dot1x_NW_MsgTask_2: 1x_ptsm.c:544 Max EAPOL-key M1 retransmissions exceeded for client e8:c1:d7:00:7a:2a (ipad 4)
    1/8/2019 2:17:30 PM    cisco-capwap-controller    Warning  NY-WC-2504-01: *Dot1x_NW_MsgTask_6: 1x_ptsm.c:544 Max EAPOL-key M1 retransmissions exceeded for client d4:a1:48:f3:ce:0e (ipad 5)
    1/8/2019 2:17:27 PM    cisco-capwap-controller    Warning  NY-WC-2504-01: *Dot1x_NW_MsgTask_2: 1x_ptsm.c:544 Max EAPOL-key M1 retransmissions exceeded for client e8:c1:d7:00:7a:2a (ipad 6)
*apfReceiveTask: apf_ms.c:7398 Could not find the mobile e8:c1:d7:00:7a:b6 in internal database (For every Ipad)
cisco--controller    Error    WLC-2504-01: *Dot1x_NW_MsgTask_6: 1x_ptsm.c:730 Client e8:c1:d7:00:7a:b6 may be using an incorrect PSK (for Every Ipad)
Leo Laohoo
1. Update the firmware of the controller;
2. What radio are the wireless clients connected to before they fall off? 2.4 Ghz or 5.0 Ghz?
3. What was their RSSI prior to falling off?
4. Co-channel interference check?
5. Have you tried to reproduce the issue?
Alex Pfeil
Level 7
Level 7
Were the clients able to connect at all when this was happening?
Did you resolve the issue?
yes we were able to fix it, realized the timeout was 1800 seconds so we changed it and it worked
we made the change on the WLAN SSID - see link as an example https://rscciew.wordpress.com/2014/05/07/timeout-setting-on-wireless-lan-controller/ Message back if you need any other assistance
