Highlighted
Beginner
Will enable secret work if tacacs is configured?
Below is the current config and when we login with our id, it directly goes to privilege mode(router #). We are now planning to add enable secret. Will it work with current config or any other changes are required for it to work with TACACS?
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ local
aaa accounting commands 15 default start-stop group tacacs+
Everyone's tags (2)
1 REPLY 1
Highlighted
Re: Will enable secret work if tacacs is configured?
Hi @Shruti3482 ,
Yes, it will work. You have to set default privilege as 1 and maximum privilege as 15 on the shell profile on TACACS.
Refer for ACS TACACS Profile and Refer for ISE TACACS Profile
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Content for Community-Ad
