293
Highlighted
Beginner
Wireless 4400 Controller
We have a 4400 Controller and a administrator asked if we could use the scheduling tool.  Basically to resetup a user account every week since there is a timeout feature on the account.  I guess another soultion would be if we could give that one account longer access.
Everyone's tags (1)
5 REPLIES 5
Hall of Fame Guru
Tracy
You should probably move this post to the Wireless forums where you are more likely to get the help you need.
Jon
Hall of Fame Master
Re: Wireless 4400 Controller
Your better off just adjusting the timer longer. Don't think scheduling will allow you to reset the user credentials.
-Scott
Beginner
I am reading through the Cisco Deployment Guide : Cisco Guest Access using the Cisco Wireless Lan Controller.  There is a feature in this document called Schedule WCS Guest User Account.  This is the feature I seem to be missing on my controller.  Not sure if I am looking in the wrong place or the 4400 needs to be upgraded.  Does anyone else use this feature?
Hall of Fame Master
Many people use the guest feature, but typically my customers have someone create individual accounts or they have a generic that they change every week or month.  They just create a regular local net user and not a guest user.  This way they can have the account valid until they change it.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Hall of Fame Master
The latest v7.0 should be the code you should be on:
AIR-WLC4400-K9-7-0-240-0.aes
You also need the ER imagae.
AIR-WLC4400-K9-7-0-240-0-ER.aes
http://software.cisco.com/download/release.html?mdfid=279911193&flowid=7586&softwareid=280926587&release=7.0.240.0&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Scott
-Scott
Content for Community-Ad
August's Community Spotlight Awards
