04-13-2019 07:04 AM - edited 07-05-2021 10:15 AM
Hello Team,
We have two WLC 3504 in HA with management VLAN XX. Also Access point are connected to this WLC with same VLAN XX. DHCP has been configured on separate Windows Server.
Problem is that, Access point is able to get Management VLAN IP to connect with network but Users those are trying to connect Access Point are not able to get IP address from DHCP.
Could you please anyone help me out?
04-13-2019 09:44 AM
- Is there any 'user activiy' in the DHCP server's dhcp=logs ?
M.
04-14-2019 10:51 PM
Today we have created One new SSID without having any RADIUS server authentication.
Client is able to get IP address from this SSID and also they can access Network via these SSID.
So we have to use RADIUS server authentication, Can anybody suggest what will be the issue in configuration.
Thanks in Advance.
04-15-2019 05:23 AM
Is it possible to post both the SSID config by removing the ip and ssid name details?
Also is the authentication is getting successful while using Radius?
Are u using NPS or ISE as radius?
04-16-2019 12:17 AM
When i run test aaa show radius command i see the message below
Radius test request
Wlan-id...........................0
ApGroup Name...............none
No Radius Test Response.
We are using NPS as radius.
04-16-2019 01:59 AM
DHCP part will come post the successful authentication via Radius server. On the WLC go to monitoring ->Client- > Filter with MAC address of client and then click on client check what is the status of client whether its DHCP_Req or 802.1x req.
If its DHCP required please try to make this changes and see if its working.
Option 1:
Check the DHCP proxy is enabled or not ? If its enabled. Make sure that DHCP IP address is configured on the Interface of clients in WLC. (Controller > Advanced > DHCP) Ref DHCP Proxy
Option 2:
Make the AP as Flexconnect from local. Enable the Flexconnect local switching option in SSID under advanced.
If DHCP addr. assignment is enabled on SSID please disable it. Also disable the DHCP proxy.
If the status of client is 802.1x req. then you have to troubleshoot on authentication part.
08-16-2021 04:25 AM
This worked for me
04-14-2019 11:48 AM - edited 04-14-2019 11:49 AM
Is it local or flex SSID?
Can you please share the WLAN configuration by hiding the SSID name and some private details ?
04-16-2019 12:13 AM
We have 2 WLC in HA. We have used 4 ip addresses
WLC 1:
Management IP : 10.-.-.126
Redundancy Management IP: 10.-.-.124
Peer Redundancy Management IP: 10.-.-.123
WLC 2:
Management IP: 10.-.-.125
Peer Redundancy Management IP: 10.-.-.124
I would like to know whether the redundancy IP addresses play any role with Radius server? We have added both the management IP addresses of WLC's to communicate with my radius servers through my firewall. Is redundancy ip address also required? or they are used only between the 2 WLC's to check the health of each other.
As mentioned i have attached the config file. Please let me know if you want any more details.
04-16-2019 02:08 AM
No, Redundancy IP will not communicate for radius authentication. Also no need to add Both controllers IP address in Radius server. Radius request will be sent through the Management IP you are accessing, Secondary Controller also will have the Same Management IP post HA SSO enabled.
Please disable the DHCP Server and DHCP Address assigment option in SSID under advanced. On the Interface of Management check whether DHCP IP address is configured or not ? If not please configure it. Check my another reply on the same post as well please.
Hope it will resolve your issue.
04-17-2019 10:26 PM
We Entered the Radius key again in the WLC and it resolved the problem. Thanks for your help.
04-18-2019 05:49 AM
Great!
If my response was helpful or resolved your issue. Please mark as solution and rate the same.
