07-30-2018 11:19 PM - edited 07-05-2021 08:54 AM
The web authentication page not able to redirect in chrome browser.
Solved! Go to Solution.
07-30-2018 11:34 PM
07-30-2018 11:34 PM
What version of software you running on your WLC ?
Rasika
07-30-2018 11:56 PM
Software Version | 8.2.170.0 |
07-30-2018 11:57 PM
07-31-2018 12:10 AM
Check with below command what secure web config mode enable on your WLC
In my case, I am running 8.2.164.0 with below config & I can access WLC GUI using chrome
(WLC)>show network summary
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Disable
Secure Web Mode RC4 Cipher Preference....... Disable
Secure Web Mode SSL Protocol................ Disable
Rasika
07-31-2018 11:43 PM
07-31-2018 11:53 PM
Also please check chrome version
Our Chrome version is
Version 67.0.3396.99 (Official Build) (64-bit).
If its not same with you , Please upgrade and check again it working or not.
Waiting for your reply
08-01-2018 12:02 AM
Hi Sujith,
You can disable HTTP access using below command
config network webmode disable
This command allows users to access the controller GUI using "http://ip-address." The default value is disabled. Web mode is not a secure connection.
You can do it via Management -> HTTP-HTTPS config page as well (see any certificate install under that page for webadmin purposes)
Regarding Chrome version, I think I had that version, but when I clicked it upgraded to below. No problem with any of those.
Version 68.0.3440.84 (Official Build) (64-bit)
Rasika
*** Pls rate all useful responses ***
07-31-2018 11:53 PM
07-30-2018 11:43 PM
07-30-2018 11:57 PM
08-12-2018 07:26 AM
Still the issue is there . IF we install third party certificate it will be solve or not?
08-12-2018 07:26 AM
08-12-2018 08:42 AM
You need to make sure if you install a 3rd party certificate that is not generated from a root CA that is new as that root CA might not be in the trusted root CA on guest devices. Ran into that once and the Cert company regenerated a new cert from an older Root CA.
You can always disable https for guest also and don’t worry about dealing with any cert.
